DirectFB-examples tar file for i.MX6
已解决
跳至解决方案
2,794 次查看
Tarek
Senior Contributor I
Hi Guy,
The DirectFB-examples-1.2.0.tar.gz is not available in the pkgs directory in LTIB.
Can you please provide it?
Tarek
标签 (3)
1 解答
1,406 次查看
jimmychan
You can download it from http://directfb.org/?path=Main%2FDownloads&page=1
Then put it in LTIB pkg folder.
在原帖中查看解决方案
2 回复数
1,407 次查看
jimmychan
1,406 次查看
Tarek
Just a remark:
For current version of DirectFB_1.4 you will need example 1.2.
Please correct the spec file
T
