Difference between i.MX 8QuadMax & i.MX 8QuadXPlus PCIe Interface
Ray_Liao
I have a question about i.MX 8QuadMax & i.MX 8QuadXPlus PCIe Interface
I evaluate to use i.MX 8QuadMax MEK and i.MX 8QuadXPlus MEK to interact with specific Wi-Fi/BT PCIe device when development
For minimizing the difference,
I want to know is there any difference between i.MX 8QuadMax MEK M.2 connector(J12) and i.MX 8QuadXPlus MEK (J5) when I set i.MX 8QuadMax MEK has only one PCIe Interface
Did it use the same PCIe controller and driver?
riteshmpatel
Hi @Ray_Liao,
I hope you are doing well.
Both i.MX8QM and i.MX8QXP has a similar PCIe interface and uses the same PCIe driver.
Thanks & Regards,
Ritesh M Patel
Ray_Liao
Hi @riteshmpatel
Thanks for your reply.
BR,
Ray
riteshmpatel
Hi @Ray_Liao,
Thanks & Regards,
Ritesh M Patel
