Hi all,
I'm investigating a device spec of H.264 encoder in i.MX8.
Could someone teach me following questions ?
Q1.What GOP structure of H.264 Encoder does i.MX8 support ?
Q2.What is the maximum GOP size of the H.264 Encoder (how long can the GOP be extended)?
Q3.What is the CPB (Coded Picture Buffer) size of the H.264 Encoder?
Q4.What is the output format of H.264 Encoder encoded data?
Q5.What is the supported encoding bit depth of H.264 Encoder?
Ko-hey
Please find my reply inline with question.
Q1.What GOP structure of H.264 Encoder does i.MX8X support ?
[Manish] It supports programmable GOP structure, -IB...BPB...BP...
[Manish] I have not find definite answer and will update you once i get detail.
[Manish] Can you elaborate more on this question? do you want CPB for encoder or decoder?
[Manish] Output format is NV12.
[Manish] 8 bit.
Generic answer for our encoder capabilities is that we support 1080 30 fps
o Constrained baseline profile (cBP)
o Main Profile (MP)
o High Profile (HP)
Can anyone follow this question ?
Ko-hey
