Hi community,
We have a question about i.MX6SDL HDMI.
Please see chapter 34.5.314 ~ 34.5.321 in IMX6SDLRM (Rev.1).
There are no descriptions for these registers.
Would you let me know the detail of these registers?
Satoshi Shimoda
Solved! Go to Solution.
The following *CNT registers must be set before any I2C bus transaction
can take place to ensure proper I/O timing. The *CNT registers are:
- *_I2CM_SS_SCL_HCNT
- *_I2CM_SS_SCL_LCNT
- *_I2CM_FS_SCL_HCNT
- *_I2CM_FS_SCL_LCNT
The following abbreviation is used for I2C SCL clock settings:
• SS: Standard Speed
• FS: Fast Speed
• HCNT: SCL High Level counter
• LCNT: SCL Low Level counter
Yuri.
• FS: Fast Speed
Yuri.
