Default setting of MIPI-CSI2 virtual channel 0
Search instead for
torus1000
Contributor V
Hi all.
I have a question about MIPI-CSI2 setting of i.MX6 linuxBSP.
Refer to Figure 19-1 "CSI2IPU gasket connectivity" i.MX6DQ Reference Manual (rev.2  7/2014),
VC0/VC1/VC2/VC3 assigned to IPU1_CSI0/IPU1_CSI1/IPU2_CSI0/IPU2_CSI1 respectively.
On the other hands. default setting in <linux>/arch/arm/mach-mx6/board-
mx6q_sabresd.c seems VC0 assigned to IPU1_CSI1 as following;
mipi_csi2_pdate={
    ipu_id = 0;
    csi_id = 1;
    v_channel = 0; ...
(Q) Which one is correct a) VC0 merely connect to IPU1_CSI0 or
    b) VC0 is one of choice for IPU1_CSI1?
If my assumptions were wrong, please let me know.
Thanks.
Labels (2)
Yuri
If we look at MIPI CSI2 configurations of different designs all looks quite reasonable :
1.
(board-mx6q) arm2 :
( static struct mipi_csi2_platform_data mipi_csi2_pdata = { )
        .ipu_id  = 0,
        .csi_id = 0,
        .v_channel = 0,
2.
sabreauto :
        .ipu_id  = 0,
        .csi_id = 1,
        .v_channel = 1,
3.
sabrelite :
        .ipu_id  = 0,
        .csi_id = 0,
        .v_channel = 0,
But sabresd configuration was changed after “…-dual-camera-support.patch” :
        .ipu_id  = 0,
        .csi_id = 1,
        .v_channel = 0,
So, this is correct only for dual camera configuration.
Please pay attention, on the Community thread, special patch is suggested, which
provides reasonable values again :
-    .csi_id = 1,
+    .csi_id = 0,
     .v_channel = 0,
“Some Experience When Enable MIPI Camera”
https://community.freescale.com/thread/307065
https://community.freescale.com/servlet/JiveServlet/download/328301-260577/0001-support-mipi-and-par...
Yuri
Yuri
1.
(board-mx6q) arm2 :
        .ipu_id  = 0,
        .csi_id = 0,
        .v_channel = 0,
2.
sabreauto :
        .ipu_id  = 0,
        .csi_id = 1,
        .v_channel = 1,
3.
sabrelite :
        .ipu_id  = 0,
        .csi_id = 0,
        .v_channel = 0,
        .ipu_id  = 0,
        .csi_id = 1,
        .v_channel = 0,
-    .csi_id = 1,
+    .csi_id = 0,
     .v_channel = 0,
Yuri
torus1000
Contributor V
Dear Yuri,
Thank you for your clear answer.
I made a big mistake because my customer used not ltib but yocto.
Could you explain one more time with yocto source?
Sorry for waste your time. I think dtsi include same information.
Here: fsl-release-bsp/build/tmp/work/imx6qsabresd-poky-*/linux-imx/3.10.17-r0/git/arch/arm/boot/dts/imx6q*sd.dtsi
Thanks.
