Debug UART as Application UART
1,503 次查看
adityapatil
HI,
I am using im283 cpu and would like to know whether the debug UART can be made to function as application
-Thanks
标签 (2)
标记 (3)
1,363 次查看
Rita_Wang
Here you can try Disable serial console in kernel, remove kernel argument (console=XXX) from kernel command line. If you still need a console, try telnet, ssh through ethernet. Hope this can help you.
Rita
1,364 次查看
Rita_Wang
Rita
1,363 次查看
adityapatil
Thanks for the reply
-Aditya
