DP firmware issues imx8qm 6.6.36
AchimKanert1
we are facing the issue that on an imx8qm we cannot run the DP interface using the firmware provided by recent meta-freescale layer.
As described here https://github.com/Freescale/meta-freescale/issues/1887
the old firmeware still works with Scarthgap 6.6.36 Linux kernel without any problem and DP shows a screen.
Can someone take o look on this issue.
Achim Kanert
AchimKanert1
what do you mean the NXP version? We use the normal Yocto setup provided by NXP via github.
Achim Kanert
Bio_TICFSL
Looks like the firmware has an issue, try the NXP version of the BSP.
