Does iMX8M support DP Alt Mode? I am thinking of running a 4K@60fps video through USB-C.
Rgds
Dan
已解决! 转到解答。
unfortunately we don't have such demo
在原帖中查看解决方案
i.mx8mq has DP signal, so should support this DP alternate mode if you set correctly
Hi Joan,
Thanks for your reply.
Do you know if there is any iMX8MQ EVK that comes with demo software to show the DP signal through the USB port? Thanks.
