Good day,
Thank you for the register definitions. This helps a lot.
Do you perhaps have the register address & bit position for the JTAG_HEO and KTE fields?
JTAG_HEO
Addressed in paragraph 4.11.5.2: Software Enabled JTAG, it states that "By writing '1' to HAB_JDE (HAB JTAG
DEBUG ENABLE) bit in the e-fuse controller module, the JTAG is opened, regardless of its security mode"
Further in the paragraph it says: "JTAG_HEO e-fuse disables this feature"
KTE: Kill trace enable
Defined in the reference manual in paragraph 4.11.5.3: Kill Trace.
"The kill trace feature needs to be activated by burning a dedicated e-fuse. If the fuse is left intact, kill trace is never activated"
From this it seems that we need to program the fuse to enable the 'kill trace' signal
Frikkie
