DEAR ALL,
WE CAN FIND MANY DEVELOPMENT BOARDS WHICH ARE BASED ON IMAX6Q PROCESSOR LIKE SABRE LITE, NITROGEN 6, SABRE SD, REX AND ETC. ALL OF THEM USE ON BOARD RAM WITH THEIR HARDWARE DESIGN.
DO YOU HAVE ANY EXAMPLE BOARD WITH MEMORY CARD SLOT ? (WHICH WE CAN PLUG AND UNPLUG MEMORY LIKE A CARD)
ANY SUGGESTION TO REDUCE THE SPACE OF THE PCB LAYOUT ? CAN WE USE FLEX PCB IN BETWEEN MEMORY AND PROCESSOR LAYOUT AREA ?
REGARDS,
PETER.
Hi Peter
>DO YOU HAVE ANY EXAMPLE BOARD WITH MEMORY CARD SLOT ? (WHICH WE CAN PLUG AND >UNPLUG MEMORY LIKE A CARD)
sorry NXP does not provide such reference design
in general flex pcb also can be used, for layout please follow guidelines described in
i.MX6 System Development User’s Guide
https://www.nxp.com/docs/en/user-guide/IMX6DQ6SDLHDG.pdf
