@ban45
The same approach as for i.MX6S may be used with i.MX 6ULL.
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/i-MX6ULL-LPDDR2-Script-Aid/ta-p/1121785
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/i-MX6ULL-DDR3-Script-Aid/ta-p/1127297
Yuri.
I downloaded I.MX6ULL_DDR3_Script_Aid_V0.01.xlsx, but the Memory type was up to DDR3-1600 and DDR3-1866 was missing. Is it okay to enter the Memory type as DDR3-1600?
best regard.
@ban45
i.MX 6ULL MMDC supports clock rate of up to 400 MHz, so memory timings
should be based on DDR3-800 specs.
Yuri.
