Hello community,
In applicatio note AN12410 of i.MX8M Mini Power consumption measurement,
In this mode, DDRC frequency is set to 25MHz.
Is it meen that not only DDRC but also external DDR clock run at 25MHz?
In this time, it is use DLL-off mode?
Ishii.
Solved! Go to Solution.
Hi Ishii
yes
yes
Hi Ishii
yes
yes
Hello Igor,
Thank you for your quick response.
Ishii.
