DDR Data line connection between i.MX 6SoloX and DDR Memory
已解决
跳至解决方案
2,031 次查看
andy_kim
When I check the reference schematic on AN5161,
DDR Data lines between i.MX 6SoloX and DDR Memory are not connected as below
Data0 to Data0, Data1 to Data1, .... Data31 to Data31.
Instead, the connection is complicated like
Data0 - Data16, Data1 - Data17,...
What is the reason of the DDR Data connection like that?
Can we connect them according to Data Number order as normal?
Andy
1 解答
2,022 次查看
Rita_Wang
It will be OK.
Data transfer is a byte-byte transfer
在原帖中查看解决方案
5 回复数
2,029 次查看
Rita_Wang
It's will be OK, you can change the order in one byte.
2,026 次查看
andy_kim
Dear
Thanks for your prompt reply.
Is DDR operation OK even if DATA lines between i.MX and DDR memory are not connected in order while they are in one byte?
How i.MX and DDR find the right data lines respectively when data lines are connected out of order in one byte?
I am looking forward to seeing your reply.
Andy
2,023 次查看
Rita_Wang
It will be OK.
2,019 次查看
andy_kim
Dear
Thank you for your explanation
2,016 次查看
Rita_Wang
You are welcome~~
Wish you have a nice day
