when i carry on the command ./ltib -c,the problem is following:
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(mv.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(nice.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(nice.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(od.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(od.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(printf.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(printf.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(pwd.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(pwd.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(readlink.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(readlink.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(realpath.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(realpath.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(rm.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(rm.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(rmdir.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(rmdir.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(seq.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(seq.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(sleep.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(sleep.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(sort.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(sort.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(stty.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(stty.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(sync.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(sync.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(tail.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(tail.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(tee.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(tee.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(test.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(test.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(test_ptr_hack.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(test_ptr_hack.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(touch.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(touch.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(tr.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(tr.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(true.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(true.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(tty.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(tty.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(uname.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(uname.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(uniq.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(uniq.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(usleep.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(usleep.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(uudecode.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(uudecode.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(wc.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(wc.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(who.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(who.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(whoami.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(whoami.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(yes.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(yes.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/libcoreutils/lib.a(cp_mv_stat.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/libcoreutils/lib.a(cp_mv_stat.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/libcoreutils/lib.a(getopt_mk_fifo_nod.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/libcoreutils/lib.a(getopt_mk_fifo_nod.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, debianutils/lib.a(mktemp.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file debianutils/lib.a(mktemp.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, debianutils/lib.a(run_parts.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file debianutils/lib.a(run_parts.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, debianutils/lib.a(which.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file debianutils/lib.a(which.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, editors/lib.a(awk.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file editors/lib.a(awk.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, editors/lib.a(cmp.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file editors/lib.a(cmp.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, editors/lib.a(diff.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file editors/lib.a(diff.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, editors/lib.a(patch.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file editors/lib.a(patch.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, editors/lib.a(sed.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file editors/lib.a(sed.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, editors/lib.a(vi.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file editors/lib.a(vi.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, findutils/lib.a(find.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file findutils/lib.a(find.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, findutils/lib.a(grep.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file findutils/lib.a(grep.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, findutils/lib.a(xargs.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file findutils/lib.a(xargs.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, init/lib.a(bootchartd.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file init/lib.a(bootchartd.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, init/lib.a(halt.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file init/lib.a(halt.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, init/lib.a(init.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file init/lib.a(init.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, init/lib.a(mesg.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file init/lib.a(mesg.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(ask_confirmation.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(ask_confirmation.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(bb_askpass.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(bb_askpass.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(bb_bswap_64.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(bb_bswap_64.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(bb_do_delay.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(bb_do_delay.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(bb_pwd.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(bb_pwd.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(bb_qsort.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(bb_qsort.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(change_identity.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(change_identity.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(chomp.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(chomp.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(compare_string_array.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(compare_string_array.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(concat_subpath_file.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(concat_subpath_file.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(copy_file.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(copy_file.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(correct_password.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(correct_password.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(crc32.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(crc32.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(create_icmp_socket.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(create_icmp_socket.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(device_open.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(device_open.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(dump.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(dump.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(execable.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(execable.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(fclose_nonstdin.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(fclose_nonstdin.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(fflush_stdout_and_exit.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(fflush_stdout_and_exit.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(fgets_str.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(fgets_str.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(find_mount_point.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(find_mount_point.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(find_pid_by_name.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(find_pid_by_name.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(get_console.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(get_console.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(get_cpu_count.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(get_cpu_count.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(get_line_from_file.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(get_line_from_file.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(get_shell_name.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(get_shell_name.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(get_volsize.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(get_volsize.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(getopt32.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(getopt32.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(getpty.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(getpty.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(hash_md5_sha.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(hash_md5_sha.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(herror_msg.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(herror_msg.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(human_readable.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(human_readable.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(inet_cksum.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(inet_cksum.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(inet_common.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(inet_common.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(info_msg.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(info_msg.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(inode_hash.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(inode_hash.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(isdirectory.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(isdirectory.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(kernel_version.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(kernel_version.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(lineedit.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(lineedit.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(lineedit_ptr_hack.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(lineedit_ptr_hack.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(login.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(login.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(loop.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(loop.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(make_directory.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(make_directory.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(makedev.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(makedev.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(match_fstype.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(match_fstype.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(mode_string.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(mode_string.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(obscure.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(obscure.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(parse_config.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(parse_config.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(parse_mode.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(parse_mode.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(percent_decode.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(percent_decode.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(perror_nomsg_and_die.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(perror_nomsg_and_die.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(pidfile.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(pidfile.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(print_flags.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(print_flags.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(printable.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(printable.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(printable_string.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(printable_string.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(process_escape_sequence.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(process_escape_sequence.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(procps.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(procps.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(progress.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(progress.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(pw_encrypt.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(pw_encrypt.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(read_key.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(read_key.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(read_printf.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(read_printf.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(recursive_action.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(recursive_action.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(remove_file.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(remove_file.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(rtc.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(rtc.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(run_shell.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(run_shell.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(safe_gethostname.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(safe_gethostname.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(safe_poll.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(safe_poll.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(safe_strncpy.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(safe_strncpy.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(setup_environment.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(setup_environment.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(signals.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(signals.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(simplify_path.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(simplify_path.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(single_argv.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(single_argv.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(speed_table.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(speed_table.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(str_tolower.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(str_tolower.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(systemd_support.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(systemd_support.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(u_signal_names.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(u_signal_names.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(udp_io.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(udp_io.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(unicode.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(unicode.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(update_passwd.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(update_passwd.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(utmp.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(utmp.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(uuencode.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(uuencode.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(vfork_daemon_rexec.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(vfork_daemon_rexec.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(wfopen_input.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(wfopen_input.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(write.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(write.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(xatonum.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(xatonum.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(xconnect.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(xconnect.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(xgetcwd.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(xgetcwd.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(xgethostbyname.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(xgethostbyname.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(xrealloc_vector.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(xrealloc_vector.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(xregcomp.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(xregcomp.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(perror_nomsg.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(perror_nomsg.o)
collect2: error: ld returned 1 exit status
make: *** [busybox_unstripped] Error 1
error: Bad exit status from /home/xiexp/Desktop/ltib/tmp/rpm-tmp.85757 (%build)
RPM build errors:
Build time for busybox: 5 seconds
Failed building busybox
f_buildrpms() returned an error, exiting
traceback:
main:572
Started: Wed Apr 22 15:24:54 2015
Ended: Wed Apr 22 15:25:02 2015
Elapsed: 8 seconds
These packages failed to build:
busybox
Build Failed
the problem is that busybox_unstripped uses VFP register arguments,and my configure with imx6q.cf,where is have the commad
# Toolchain selection.
CONFIG_TOOLCHAIN_ARMEABI_FSL_GCC_LINARO_MULTILIB=y
# CONFIG_TOOLCHAIN_ARMEABI_FSL_GCC_MULTILIB is not set
# CONFIG_TOOLCHAIN_ARMEABI_GLIBC1 is not set
# CONFIG_TOOLCHAIN_ARMEABI_CODE_SOURCERY is not set
# CONFIG_TOOLCHAIN_ARMEABI_CUSTOM is not set
CONFIG_TOOLCHAIN="gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12-1.i386.rpm"
CONFIG_TOOLCHAIN_PATH="/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9"
CONFIG_TOOLCHAIN_PREFIX="arm-linux-gnueabihf-"
should i have some change?
