Cross_compile by LTIB,the problem is coming
5,083 次查看
xiexp
when i carry on the command ./ltib -c,the problem is following:
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(mv.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(nice.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(nice.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(od.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(od.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(printf.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(printf.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(pwd.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(pwd.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(readlink.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(readlink.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(realpath.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(realpath.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(rm.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(rm.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(rmdir.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(rmdir.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(seq.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(seq.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(sleep.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(sleep.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(sort.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(sort.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(stty.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(stty.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(sync.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(sync.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(tail.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(tail.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(tee.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(tee.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(test.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(test.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(test_ptr_hack.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(test_ptr_hack.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(touch.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(touch.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(tr.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(tr.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(true.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(true.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(tty.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(tty.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(uname.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(uname.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(uniq.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(uniq.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(usleep.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(usleep.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(uudecode.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(uudecode.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(wc.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(wc.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(who.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(who.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(whoami.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(whoami.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/lib.a(yes.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/lib.a(yes.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/libcoreutils/lib.a(cp_mv_stat.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/libcoreutils/lib.a(cp_mv_stat.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, coreutils/libcoreutils/lib.a(getopt_mk_fifo_nod.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file coreutils/libcoreutils/lib.a(getopt_mk_fifo_nod.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, debianutils/lib.a(mktemp.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file debianutils/lib.a(mktemp.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, debianutils/lib.a(run_parts.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file debianutils/lib.a(run_parts.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, debianutils/lib.a(which.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file debianutils/lib.a(which.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, editors/lib.a(awk.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file editors/lib.a(awk.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, editors/lib.a(cmp.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file editors/lib.a(cmp.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, editors/lib.a(diff.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file editors/lib.a(diff.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, editors/lib.a(patch.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file editors/lib.a(patch.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, editors/lib.a(sed.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file editors/lib.a(sed.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, editors/lib.a(vi.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file editors/lib.a(vi.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, findutils/lib.a(find.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file findutils/lib.a(find.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, findutils/lib.a(grep.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file findutils/lib.a(grep.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, findutils/lib.a(xargs.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file findutils/lib.a(xargs.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, init/lib.a(bootchartd.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file init/lib.a(bootchartd.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, init/lib.a(halt.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file init/lib.a(halt.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, init/lib.a(init.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file init/lib.a(init.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, init/lib.a(mesg.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file init/lib.a(mesg.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(ask_confirmation.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(ask_confirmation.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(bb_askpass.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(bb_askpass.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(bb_bswap_64.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(bb_bswap_64.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(bb_do_delay.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(bb_do_delay.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(bb_pwd.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(bb_pwd.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(bb_qsort.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(bb_qsort.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(change_identity.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(change_identity.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(chomp.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(chomp.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(compare_string_array.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(compare_string_array.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(concat_subpath_file.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(concat_subpath_file.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(copy_file.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(copy_file.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(correct_password.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(correct_password.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(crc32.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(crc32.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(create_icmp_socket.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(create_icmp_socket.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(device_open.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(device_open.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(dump.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(dump.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(execable.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(execable.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(fclose_nonstdin.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(fclose_nonstdin.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(fflush_stdout_and_exit.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(fflush_stdout_and_exit.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(fgets_str.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(fgets_str.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(find_mount_point.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(find_mount_point.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(find_pid_by_name.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(find_pid_by_name.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(get_console.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(get_console.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(get_cpu_count.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(get_cpu_count.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(get_line_from_file.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(get_line_from_file.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(get_shell_name.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(get_shell_name.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(get_volsize.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(get_volsize.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(getopt32.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(getopt32.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(getpty.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(getpty.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(hash_md5_sha.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(hash_md5_sha.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(herror_msg.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(herror_msg.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(human_readable.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(human_readable.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(inet_cksum.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(inet_cksum.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(inet_common.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(inet_common.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(info_msg.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(info_msg.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(inode_hash.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(inode_hash.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(isdirectory.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(isdirectory.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(kernel_version.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(kernel_version.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(lineedit.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(lineedit.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(lineedit_ptr_hack.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(lineedit_ptr_hack.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(login.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(login.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(loop.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(loop.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(make_directory.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(make_directory.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(makedev.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(makedev.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(match_fstype.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(match_fstype.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(mode_string.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(mode_string.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(obscure.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(obscure.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(parse_config.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(parse_config.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(parse_mode.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(parse_mode.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(percent_decode.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(percent_decode.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(perror_nomsg_and_die.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(perror_nomsg_and_die.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(pidfile.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(pidfile.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(print_flags.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(print_flags.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(printable.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(printable.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(printable_string.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(printable_string.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(process_escape_sequence.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(process_escape_sequence.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(procps.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(procps.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(progress.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(progress.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(pw_encrypt.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(pw_encrypt.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(read_key.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(read_key.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(read_printf.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(read_printf.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(recursive_action.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(recursive_action.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(remove_file.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(remove_file.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(rtc.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(rtc.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(run_shell.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(run_shell.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(safe_gethostname.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(safe_gethostname.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(safe_poll.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(safe_poll.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(safe_strncpy.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(safe_strncpy.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(setup_environment.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(setup_environment.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(signals.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(signals.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(simplify_path.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(simplify_path.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(single_argv.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(single_argv.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(speed_table.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(speed_table.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(str_tolower.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(str_tolower.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(systemd_support.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(systemd_support.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(u_signal_names.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(u_signal_names.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(udp_io.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(udp_io.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(unicode.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(unicode.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(update_passwd.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(update_passwd.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(utmp.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(utmp.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(uuencode.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(uuencode.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(vfork_daemon_rexec.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(vfork_daemon_rexec.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(wfopen_input.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(wfopen_input.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(write.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(write.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(xatonum.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(xatonum.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(xconnect.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(xconnect.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(xgetcwd.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(xgetcwd.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(xgethostbyname.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(xgethostbyname.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(xrealloc_vector.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(xrealloc_vector.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(xregcomp.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(xregcomp.o)
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: error: busybox_unstripped uses VFP register arguments, libbb/lib.a(perror_nomsg.o) does not
/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9/bin/../lib/gcc/arm-linux-gnueabihf/4.9.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file libbb/lib.a(perror_nomsg.o)
collect2: error: ld returned 1 exit status
make: *** [busybox_unstripped] Error 1
error: Bad exit status from /home/xiexp/Desktop/ltib/tmp/rpm-tmp.85757 (%build)
RPM build errors:
Build time for busybox: 5 seconds
Failed building busybox
f_buildrpms() returned an error, exiting
traceback:
main:572
Started: Wed Apr 22 15:24:54 2015
Ended:   Wed Apr 22 15:25:02 2015
Elapsed: 8 seconds
These packages failed to build:
busybox
Build Failed
the problem is that busybox_unstripped uses VFP register arguments,and my configure with imx6q.cf,where is have the commad
# Toolchain selection.
CONFIG_TOOLCHAIN_ARMEABI_FSL_GCC_LINARO_MULTILIB=y
# CONFIG_TOOLCHAIN_ARMEABI_FSL_GCC_MULTILIB is not set
# CONFIG_TOOLCHAIN_ARMEABI_GLIBC1 is not set
# CONFIG_TOOLCHAIN_ARMEABI_CODE_SOURCERY is not set
# CONFIG_TOOLCHAIN_ARMEABI_CUSTOM is not set
CONFIG_TOOLCHAIN="gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12-1.i386.rpm"
CONFIG_TOOLCHAIN_PATH="/home/xiexp/Desktop/gcc-linaro-arm-linux-gnueabihf-4.9"
CONFIG_TOOLCHAIN_PREFIX="arm-linux-gnueabihf-"
should i have some change?
标记 (1)
10 回复数
4,441 次查看
xiexp
HI Dan Wang.
my aim to compile with gcc 4.9hf to get the ubuntu 12.04hf ,And my configure is change the compile plexrm-linux-gcchf 4.9,and set the Path,also i aem change set the gcc enviorment that is O2  -mfloat-abi=hard -mfpu=vfp
4,441 次查看
Rita_Wang
Hi xie xp,
Which version BSP and board are you using? And which version of ubuntu are you using?
Have a great day
Dan
4,441 次查看
xiexp
thank you for your attention.
my demoboard is imx6q, using the L3.035_4.1.0_130816_source, my computer is ubuntu 12.04,32bit .Now i want to compile the armhf .and the problem coming .
4,441 次查看
Rita_Wang
Hi xie xp,
I see that in your thread :
and you are using ubuntu 12.04,32bit, the setting is not right. You'd better have a check.
Have a great day
Dan
4,441 次查看
xiexp
why this setting is not right,i not see .can you give me some reference,how to compile with the armhf system. thank you
4,432 次查看
Rita_Wang
Hi xie xp,
Here my environment is ubuntu 12.04 64bit, you can refer to my tool chain selection in the attachment.
Have a great day
Dan
4,432 次查看
xiexp
And  my system is 32bit ,want to get the 32bit ubuntu 12.04hf
4,432 次查看
Rita_Wang
Hi xie xp,
Here I do not know what you have set and configured? Could you show me details what have you done?
Have a great day
Dan
4,432 次查看
Rita_Wang
Hi xie xp,
Here you can try to modify the spec file, and comment the line I have lined out for you, as follows:
Open this file: ltib/dist/lfs-5.1/base_libs/base_libs.spec
perl -w -e '
# @ARGV = grep { `file $_` =~ m,ASCII C program text, } @ARGV;
# exit (0) unless @ARGV;
Then run ./ltib build.
You can have try, then give feedback to me.
Have a great day
Dan
4,432 次查看
xiexp
i have modify this configure before using the LTIB, so i think the question is not here
