Creating a ramdisk on the i.MX28 EVK
1,533 次查看
paulbannister
I'm trying to set up a ramdisk on the i.MX28 EVK
I have found a web post that suggests the following
mkdir /tmp/ramdisk; chmod 777 /tmp/ramdisk
mount -t tmpfs -o size=32M tmpfs /tmp/ramdisk/
Both commands appear to complete successfully (No warning/error messages), but when I
ls /mnt
I do not see the ramdisk mounted
I am new to Linux, so I apologise if this is a trivial misunderstanding, but I would appreciate any help offered.
Many thanks!
标记 (2)
1,249 次查看
paulbannister
Many thanks for your help!
1,249 次查看
SergioSolis
Hello Paul,
Can you please type "mount" in your linux terminal?, you should see a row like this:
tmpfs on /tmp/ramdisk type tmpfs (rw,size=32M)
Here is a small tutorial about tmpfs and ramfs, it may help you clarify any doubt you have:
Overview of RAMFS and TMPFS on Linux
