Crash in libgal.so
Crash in libgal.so
2,036 次查看
rémicohen-scali
Hi! I got a "crash" in libgal.so when I try to decipher and decode an isobmff media.
The only trace I have is "D/v_gal ( 3649): [tid=3674] Process got signal (8). To further debug the issue, you should run in debug mode"
v_gal tag is only available in libgal.so provided in device/fsl-proprietary/gpu-viv/lib dir of android sources.
Is it possible to activate this "debug mode" and how ?
I'm running on android kk 4.4.2 for Nitrogen6x (I can provides ref of gpu libs used or a media ciphered or not that exhibits the problem).
0 回复数
