I want to use CAAM for random number generation...But i couldn't write/read to CAAM job ring registers.. I tried with other CAAM registers but same...I came to know that i need more permissions to write to those registers...(correct me if i am wrong)
Can anyone suggest me what are the permissions we need to write/read in CAAM registers...?
i am a beginner in CAAM
Thanks in advance
Sreelakshmy
Solved! Go to Solution.
Hi Sreelakshmy
very simple caam tests can be found in sdk:
rt-thread/caam_test.c at master · RT-Thread/rt-thread · GitHub
or linux:
imx_sec_apps - i.MX Security Application Examples
Hi Sreelakshmy
or linux:
Hi Igor,
Thank you for the response and example codes provided.
Sreelakshmy
