Which version BSP are you using? You can refer to the section in the 2.5.3 CPU Frequency Scaling (CPUFREQ) of the document i.MX_Linux_Reference_Manual.pdf.
https://www.nxp.com/design/software/embedded-software/i-mx-software/embedded-linux-for-i-mx-applicat...
You can download here.
If you only want to use one fixed frequency you can remove others values here:
https://github.com/nxp-imx/linux-imx/blob/lf-6.1.y/arch/arm64/boot/dts/freescale/imx8qm.dtsi
In the opp-table:
a53_opp_table: a53-opp-table {
compatible = "operating-points-v2";
opp-shared;
opp-600000000 {
opp-hz = /bits/ 64 <600000000>;
opp-microvolt = <900000>;
clock-latency-ns = <150000>;
opp-896000000 {
opp-hz = /bits/ 64 <896000000>;
opp-microvolt = <1000000>;
opp-1104000000 {
opp-hz = /bits/ 64 <1104000000>;
opp-microvolt = <1100000>;
opp-1200000000 {
opp-hz = /bits/ 64 <1200000000>;
opp-suspend;
a72_opp_table: a72-opp-table {
opp-shared;
opp-600000000 {
opp-1056000000 {
opp-hz = /bits/ 64 <1056000000>;
opp-1296000000 {
opp-hz = /bits/ 64 <1296000000>;
opp-1596000000 {
opp-hz = /bits/ 64 <1596000000>;
opp-suspend;
