Conversion from Bayer RAW RGB to YUV in IMX6 Solo
Showing results forย
Search instead forย
Did you mean:ย
Yogee
We need to understand how RAW Bayer 8 bit format from Camera sensor can be converted into YUV422 or anyother format supported by IMX6 solo. There is no YUV output from Camera sensor so this has to be taken care in the IMX6 Solo IPU block. Can anyone advise us on this.
Yogee
Tags (6)
igorpadykov
Hi Yogee
one can use IPU CSC (color space/format convertion), examples
can be found in
IMX51_IPU_LIB_UG
i.MX51 IPU V3 Library User's Guide
Also please check some useful Bayer links below
https://community.freescale.com/message/331888
https://community.freescale.com/message/309833
https://community.freescale.com/message/309069
chip
