Connecting 8-bit NAND Flash Memory to i.MX535
1,404 次查看
neeveehariharan
Which Byte (NAND_DA[15..8] or NAND_DA[7..0]) should be used to interface a 8-bit NAND Flash memory to i.MX535?
Thanks & Regards,
Hari.
标签 (1)
2 回复数
1,298 次查看
NitinSonar
Hi Hari,
Use LSB to interface 8bit.
Best Regards
Nitin Sonar
1,298 次查看
Yogesh1z
Hari,
NAND_DA[7..0] should be used for 8 Bit and all 0...15 bits for 16 bit NAND Flash.
Yogesh
