Could you please help check if we can assist the customer in supporting this resolution? Previously, on the i.MX8MP, we were able to support this resolution by adding this clock in the kernel's PHY. Can the same method be applied to the ROM-5720 MX8M platform? Reference: Solved: IMX8M plus 1280*800 resolution - NXP Community
I already replied to you in your another case, did you receive it? do you mind reading it and tell me what do you need further? imx8mq has different hdmi IP from imx8mp, imx8mq needs to use tools to calculate the timings, pls check my mail again
if customer display couldn't be supported, maybe their timing couldn't be supported in the current driver, if they need add new timing, they need to use tools to generate timings, then add them in the current driver, more detailed information, pls refer to the link as below
