Hello Mariano,
FYI: I also am participating in the other discussion regarding NAND boot started by Memhet.
He and I are coincidentially trying the same thing ( booting from NAND without U-Boot ).
I have been trying to get the kernel to recognize where the rootfs is on the NAND flash's second partition as documented in section 5.1.
I am using a rootfs.jffs2 format type and have tried every which way to modify the non-key command line to make this work with no success so far.
Have you gotten this to work????
If so, could you relay the steps you did as well as what type of NAND Flash and BSP version you are on?
I will attach the NAND Flash data sheet for reference that I have on the EVK.
My BSP version is L2.6.35_10.12.01
Robert
