Communication between Linux and Zephyr using Virtio net
jim4604
In my current system, Linux runs on CPU0 while Zephyr runs on CPUs 1-3. I need to implement Virtio net communication between Linux and Zephyr. The Heterogeneous Multicore Framework's FreeRTOS implementation has a net backend that appears suitable, but I'm using Zephyr. Is there a way to achieve this with Zephyr? Alternatively, could a different implementation approach using MMIO enable direct communication between Zephyr and Linux's Virtio net? Are there any reference examples available for such implementation?
Manuel_Salas
Hello @jim4604
I hope you are doing very well.
You can take a look to the Zephyr Documentation:
https://docs.zephyrproject.org/latest/hardware/virtualization/virtio.html
Salas.
jim4604
Hi @Manuel_Salas
Thank you for your reply. Currently, Zephyr only supports guest mode. Is there any documentation on how to implement host mode?
Manuel_Salas
Hello @jim4604
Unfortunately, at this moment that is all the available information.
Salas.
