Coin cell battery on SDB DualLite
789 次查看
shichinhuang
I measure the current consumption of Coin cell battery connect to LICELL of MMPF0100 on SDB EVM,and
the current is 380uA when I remove all the power except coin cell.
I think the value is very high, especially using coin battery maintain the voltage from 2.9V to 3.0V.(see the picture below)
Does something wrong in my measurement result ?
Thanks!
Shichin
629 次查看
Yuri
  According to i.MX6 Datasheet(s), say, Table 9 (Stop Mode Current and Power Consumption)
of  IMX6DQCEC (Rev. 4, 07/2015) we can get minimal consumption (of 41 uA) for SNVS Only mode, when
VDD_SNVS_IN is powered, but all other supplies are off, and only SRTC running.
  Additional current consumption may be observed because of internal pulling up / down resistors on signals,
that are powered via VDD_SNVS, such as : BOOT_MODE, TAMPER, ONOFF, POR, PMIC_ON_REQ,
PMIC_STBY_REQ, TEST_MODE.
Yuri
629 次查看
shichinhuang
Hi Yuri,
Could you please suggestion some rechargeable coin battery components which can fit with MMPF0100 on i.MX6 platform for our reference.
Thanks!
629 次查看
Yuri
The i.MX6 SDP / SDB boards are equipped with a battery holder for ML414 battery (3V - 1mAh).
Yuri.
