Codesys Programming with phyBOARD®-Pollux i.MX8M Plus
lraja
Dear All, I am trying to Developing a PLC using phyBOARD®-Pollux i.MX 8M Plus. It is very difficult to find the suitable Codesys control for i.MX8M. I have tried to install CODESYS Control for Linux ARM SL , but unable install it and I am getting the following error,
[INFORMATION] Executing SSH command on root@192.168.0.10: Retrieving architecture from package management
[ERROR] Expected exit value of command failed: expected 0, received 127
[INFORMATION] Standard output: sh: line 1: dpkg: command not found
Kindly check and help
phyBOARD®-Pollux i.MX 8M Plus Link :
https://www.phytec.eu/en/produkte/single-board-computer/phyboard-pollux/
Bio_TICFSL
Maybe someone at @phytec will help you.
