Chromium on IMX8
13,274件の閲覧回数
Giacomo_
Hello community,
I am trying to compile the chromium-ozone-wayland based on Yocto hardknott (imx-5.10.35-2.0.0.xml) on IMX8MQEVK board, but the compilation fails with the error:
| Package dri was not found in the pkg-config search path.
| Perhaps you should add the directory containing `dri.pc'
| to the PKG_CONFIG_PATH environment variable
| No package 'dri' found
| See //content/gpu/BUILD.gn:141:18: which caused the file to be included.
| configs += [ "//build/config/linux/dri" ]
| WARNING: exit code 1 from a shell command.
In my previous version (Yocto Warrior) I was able to fix it by adding this dependency:
DEPENDS += " mesa "
but this trick no longer works, has anyone successfully compiled chromium?
I know... There is no support for Chromium, I am just asking.
ラベル(2)
タグ(1)
13,235件の閲覧回数
Jeroen_H
Just to let you know, I'm trying to buildby using this patch right now:
https://github.com/OSSystems/meta-browser/issues/528
Seach for "0013-Only-DRI-for-x11.txt" and adapt to your code version.
But, it takes a while to build Chromium, I'll post my finding later.
Hopefully DRI isn't needed on iMX8 and Wayland.
Cheers,
Jeroen.
12 返答(返信)
3,891件の閲覧回数
karl1688
I've seen the similar problem when compile 117.0.5938.132.
And this problem has been resolved by following https://github.com/OSSystems/meta-browser/issues/528#issuecomment-2123583852
Looking for the last if condition, add more condition "ozone_platform_x11" then recompile Chromium browser.
117.0.5938.132
13,227件の閲覧回数
Rita_Wang
13,198件の閲覧回数
Jeroen_H
Hi!
Thanks for pointing us out to the document. I've already gone through these steps.
Unfortunately, adding mesa to the depends, and building seperately still produced errors during do_configure().
Kind regards,
Jeroen.
13,216件の閲覧回数
Giacomo_
Backporting? Yes, I can evaluate this too, thanks.
13,255件の閲覧回数
Giacomo_
here you are my bbappend:
chromium-ozone-wayland_83.0.4103.116.bbappend
it contains only one line:
DEPENDS += " mesa "
13,247件の閲覧回数
Jeroen_H
Okay, thanks, I'll have a look
13,236件の閲覧回数
Jeroen_H
Cheers,
Jeroen.
13,217件の閲覧回数
Giacomo_
Yes please, let me know the outcome.
13,199件の閲覧回数
Jeroen_H
Building succeeded, I have chromium (83.0.4103.116) running now on iMX8M Mini, weston-wayland, and using the GPU of the iMX.
I'm using Zeus btw.
Performance looks good.
Still doing some testing, but I think you can take it from here
Jeroen.
12,670件の閲覧回数
r_trivedi123
Hi Jeroen,
Can you share,
Which BSP you used ?
How did you build (for wayland running on GPU ) ? , basically build step doc or pointers.
Any performance statistics or issues you found ?
Appreciate your guidance.
Rutvij
13,163件の閲覧回数
Giacomo_
Kudos to Jeroen (not the button only).
This is the way to go.
Thank you for helping!
13,260件の閲覧回数
Jeroen_H
I have the same issue (iMX8M Mini, using Zeus 5.4.47) , no solution found yet.
Can you tell me the exact version of Yocto Warrior (or actually the version of Chromium) you've been using previously?
Just wanted to have a look at the differences....
