Change the GPIO default level after the board is powered on
566 次查看
Keanight
Hi there,
The SD2_RESET_B(GPIO2_IO19) Pin on i.MX8 mm ekv is reset to high at the very beginning of the booting phase. Is there any way to change this? We want to reuse this pin for another purpose instead of an SD card, and this requires this gpio remain low during the whole booting process.
0 回复数
