Change pin configuration during runtime
2,111 次查看
roman_g1
i need to reconfigure my I2C clock and data line to GPIO during runtime.
How is it possible on imx8-m4?
Roman
1,965 次查看
b36401
Unfortunately runtime pin configuration is not supported by the BSP.
However you can try to write to IOMUX registers directly from application.
1,965 次查看
roman_g1
Ok, thank you for your reply.
Is there a given sequence to write to register for changing the pin configuration?
For example if i want to write to MIPI_DSI1_GPIO0_00 register to set the mode to "000b".
Is the mux_mode field to set enough?
