Certain backlight levels (253) cause the dispaly on my SMD to flicker, how can I fix it?
Philip_FSL
In order to correct this situation, a recommended solution is to change the PWM period used for controlling the backlight.  In the Freescale BSP the can be achieved for the SMD with the following patch:
diff --git a/arch/arm/mach-mx5/mx53_smd.c b/arch/arm/mach-mx5/mx53_smd.c
index 46188fd..f4bbe5a 100644
--- a/arch/arm/mach-mx5/mx53_smd.c
+++ b/arch/arm/mach-mx5/mx53_smd.c
@@ -499,7 +499,7 @@ static struct platform_pwm_backlight_data mxc_pwm_backlight_data = {
        .pwm_id = 1,
        .max_brightness = 255,
        .dft_brightness = 128,
-       .pwm_period_ns = 50000,
+       .pwm_period_ns = 45454,
