I have enabled the plugin Mode in u-boot and I am trying to boot QUAD with SPL and u-boot.bin combination. I am doing for a test case. I flashed those images using MFGTOOLS. When i tried to boot , it is not booting am not getting any log in minicom. But it boots perfectly when i use u-boot.imx instead of SPL and u-boot.bin.
After that i found the fix for not booting with SPL and u-boot.bin .
To solve issue in booting SPL with plugin mode, I am booting it in DDR memory instead of internal SRAM memory.
what is the reason behind i am not able to boot it in the internal SRAM ??
Is there any restriction with the plugin mode booting??
Manoj
Hi Manoj
reason may be that uboot size is too big for internal SRAM memory,
also this may be posted on uboot mail list:
