Cannot download BSP 3.10.17 (Yocto)
3,326 次查看
faisaltaj
I have wasted plenty of time trying to work around a way to get through this problem. I am exactly following Freescale_Yocto_Project_User's_Guide.pdf instructions to get hold of Yocto Project layers but no matter what I do, end result is always same:
after configuring git with name and email add:
I executed this:
ubuntu@ubuntu:$ repo init -u git://git.freescale.com/imx/fsl-arm-yocto-bsp.git -b imx-3.10.17-1.0.2_ga
result:
fatal: cannot obtain manifest git://git.freescale.com/imx/fsl-arm-yocto-bsp.git
Yes I am behind proxy server. One solution I found looking around was to configure git with further parameters:
git config --global http.proxy http://proxyuser:proxypwd@proxy.server.com:8080proxypwd@proxy.server.com:8080
git config --global https.proxy https://proxyuser:proxypwd@proxy.server.com:8080proxypwd@proxy.server.com:8080
did that too, but still the same result.
Have anyone before had faced this scenario? Please help when you got it fixed.
Thanking in advance.
Faisal
标签 (3)
标记 (3)
2,087 次查看
franckmaillot
use http://git.freescale.com/git/cgit.cgi/imx/whatever.git instead. It looks like a cgi script is used to give you access to the git repository over http.
git config http_proxy is still required.
Franck
2,087 次查看
rodrigoaldana
Hi Faisal,
I think the problem the problem is in your proxy configuration,
You might find this link useful:
https://wiki.yoctoproject.org/wiki/Working_Behind_a_Network_Proxy
Rodrigo
2,087 次查看
gusarambula
rodrigoaldana, would you please help on this?
