Hi community,
I havea a question about i.MX6 PLL.
Please see chapter 18.7.1 in IMX6DQRM Rev.3, we can select REF_CLK_24M, CLK1, CLK2, and XOR for bypass source.
Then, is this setting enabled when PLL is not bypass mode?
In other words, can we use CLKx_P/CLKx_N for PLL clock source not only in bypass mode but also normal mode?
Satoshi Shimoda
Solved! Go to Solution.
Hi Satoshi
CLKx_P/CLKx_N can not be used for PLL clock source.
Hi Satoshi
Dear Igor,
Thank you for your prompt reply.
Ok, I understood CLKx_P/CLKx_N can be used for "bypass source" only.
Satoshi Shimoda
