Can the address of the interrupt vector table of imx283 be placed in its own defined location
Search instead for
hi
I want to run FreeRTOS on imx283, but I do n’t know that I should put the interrupt vector table at that address. After reading arm926ejs reference manual, I found that there are two addresses that can be set, one is 0x00000000 and one is 0xFFFFF000, but 0xFFFFF000 is ROM, how can I write it??
Hello Jack,
Sorry you can not rewrite the ROM location, please read the MX28 manual:
https://www.nxp.com/docs/en/reference-manual/MCIMX28RM.pdf
hi
Can you tell me which chapter I should read?
I read the reference manual but found that there is 0xFFFF0000 written in this place. This is not the address in RAM. I checked the uboot code provided by you and there is a TEXT_BASE value of 0x41008000. How did this come out?
Sent from my iPhone
