Can't run blhost.exe on Windows 10 64 bit
Mike_B
I get the following Windows message when I try to run the program:
I ran it as an administrator and got the same message. Also tried running in compatibility mode for each of these operating systems with the same result:
Feel like I just have a blind spot but not sure what else to try. Any help would be appreciated.
Harvey021
Hi @Mike_B
I'd suggest you check your Windows settings, in terms of User account control, local security policy (User Account Control), to allow app to run.
Harvey
Mike_B
This turned out to be an issue with our virus scanner. We made an exception for it and now it appears to be working. Thanks for the help.
Harvey021
Hi @Mike_B
Harvey
