i have a starnge problem, i have mmc erase uboot in boot partition, but when i reboot, it is still running, where is the uboot come from? look at this as follow:
U-Boot 2015.04-14475-g75887f8-dirty (Sep 29 2016 - 14:07:15)
CPU: Freescale i.MX6Q rev1.5 at 792 MHz
CPU: Temperature 41 C
Reset cause: POR
Board: MX6-SabreSD
I2C: ready
DRAM: 3.8 GiB
PMIC: PFUZE100 ID=0x10
MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2, FSL_SDHC: 3
mmc get env dev=0
*** Warning - bad CRC, using default environment
No panel detected: default to SAMSUNG-LTM230HL08
Display: SAMSUNG-LTM230HL08 (1920x1080)
In: serial
Out: serial
Err: serial
check_and_clean: reg 0, flag_set 0
Fastboot: Normal
flash target is MMC:0
Bad partition index:1 for partition:boot
Bad partition index:2 for partition:recovery
Bad partition index:5 for partition:system
Bad partition index:4 for partition:data
Net: Phy 1 not found
PHY reset timed out
FEC [PRIME]
Normal Boot
Hit any key to stop autoboot: 0
=> mmc erase 2 10000
MMC erase: dev # 0, block # 2, count 65536 ...
Caution! Your devices Erase group is 0x400
The erase range would be change to 0x0~0x103ff
65536 blocks erased: OK
=> mmc read 0x12000000 2 1000
MMC read: dev # 0, block # 2, count 4096 ... 4096 blocks read: OK
=> md 0x12000000
12000000: 00000000 00000000 00000000 00000000 ................
12000010: 00000000 00000000 00000000 00000000 ................
12000020: 00000000 00000000 00000000 00000000 ................
12000030: 00000000 00000000 00000000 00000000 ................
12000040: 00000000 00000000 00000000 00000000 ................
12000050: 00000000 00000000 00000000 00000000 ................
12000060: 00000000 00000000 00000000 00000000 ................
12000070: 00000000 00000000 00000000 00000000 ................
12000080: 00000000 00000000 00000000 00000000 ................
12000090: 00000000 00000000 00000000 00000000 ................
120000a0: 00000000 00000000 00000000 00000000 ................
120000b0: 00000000 00000000 00000000 00000000 ................
120000c0: 00000000 00000000 00000000 00000000 ................
120000d0: 00000000 00000000 00000000 00000000 ................
120000e0: 00000000 00000000 00000000 00000000 ................
120000f0: 00000000 00000000 00000000 00000000 ................
12000100: 00000000 00000000 00000000 00000000 ................
12000110: 00000000 00000000 00000000 00000000 ................
12000120: 00000000 00000000 00000000 00000000 ................
12000130: 00000000 00000000 00000000 00000000 ................
12000140: 00000000 00000000 00000000 00000000 ................
12000150: 00000000 00000000 00000000 00000000 ................
12000160: 00000000 00000000 00000000 00000000 ................
12000170: 00000000 00000000 00000000 00000000 ................
12000180: 00000000 00000000 00000000 00000000 ................
12000190: 00000000 00000000 00000000 00000000 ................
120001a0: 00000000 00000000 00000000 00000000 ................
120001b0: 00000000 00000000 00000000 00000000 ................
120001c0: 00000000 00000000 00000000 00000000 ................
120001d0: 00000000 00000000 00000000 00000000 ................
120001e0: 00000000 00000000 00000000 00000000 ................
120001f0: 00000000 00000000 00000000 00000000 ................
12000200: 00000000 00000000 00000000 00000000 ................
12000210: 00000000 00000000 00000000 00000000 ................
12000220: 00000000 00000000 00000000 00000000 ................
12000230: 00000000 00000000 00000000 00000000 ................
12000240: 00000000 00000000 00000000 00000000 ................
12000250: 00000000 00000000 00000000 00000000 ................
12000260: 00000000 00000000 00000000 00000000 ................
12000270: 00000000 00000000 00000000 00000000 ................
12000280: 00000000 00000000 00000000 00000000 ................
12000290: 00000000 00000000 00000000 00000000 ................
120002a0: 00000000 00000000 00000000 00000000 ................
120002b0: 00000000 00000000 00000000 00000000 ................
120002c0: 00000000 00000000 00000000 00000000 ................
120002d0: 00000000 00000000 00000000 00000000 ................
120002e0: 00000000 00000000 00000000 00000000 ................
120002f0: 00000000 00000000 00000000 00000000 ................
12000300: 00000000 00000000 00000000 00000000 ................
12000310: 00000000 00000000 00000000 00000000 ................
12000320: 00000000 00000000 00000000 00000000 ................
12000330: 00000000 00000000 00000000 00000000 ................
12000340: 00000000 00000000 00000000 00000000 ................
12000350: 00000000 00000000 00000000 00000000 ................
12000360: 00000000 00000000 00000000 00000000 ................
12000370: 00000000 00000000 00000000 00000000 ................
12000380: 00000000 00000000 00000000 00000000 ................
12000390: 00000000 00000000 00000000 00000000 ................
120003a0: 00000000 00000000 00000000 00000000 ................
120003b0: 00000000 00000000 00000000 00000000 ................
120003c0: 00000000 00000000 00000000 00000000 ................
120003d0: 00000000 00000000 00000000 00000000 ................
120003e0: 00000000 00000000 00000000 00000000 ................
120003f0: 00000000 00000000 00000000 00000000 ................
it is become 0 at offset 1k in emmc device, which was uboot placed. but when i shutdown and shutup, it still runs:
Reset cause: POR
Board: MX6-SabreSD
I2C: ready
DRAM: 3.8 GiB
mmc get env dev=0
In: serial
Out: serial
Err: serial
Fastboot: Normal
PHY reset timed out
FEC [PRIME]
Normal Boot
boota mmc0
boota: bad boot image magic
Where is the uboot come from? is it in recovery.img
已解决! 转到解答。
Hi fulin
one can post this on uboot mail list, seems it was discussed already
http://lists.denx.de/pipermail/u-boot/2015-November/234113.html
in general one can try to erase in linux:
sudo dd if=/dev/zero of=/dev/mmcblk1 bs=1024 count=1024
