If I connect hdmi cable into our board,sometimes I can't get EDID from HDMI
the message are as below:
mxc_hdmi mxc_hdmi: No modes read from edid
mxc_hdmi mxc_hdmi: create default modelist
when I plug HDMI cable to our board slowly,this situation is easier to appear
On the contrary,if I plug HDMI cable quickly,this situation is not easier to appear
And even if I can get EDID ,sometimes it will set wrong resloution.
cat /sys/class/graphics/fb0/mode
S:640x480p-60 <--wrong resloution
Please help to investigate this issue.
Thanks.
Hi charles
one can check with other monitor, use shorter
cable or check connectors. Ground of devices also
may be problem, connect their cases with wire.
