I am a beginner of i.mx28evk. I want to use a nand flash having 512MB capacity with this board. The board is having NAND flash socket. Please suggest me the part no for which is compatible with this board.
Solved! Go to Solution.
Hi Bhavya,
You can take a look at hynix HY27UF084G2B or
Samsung K9G4G08U0A
Hope this helps
Alfredo
for exmple S34ML04TFI (Spansion SLC NAND Flash). Or lot of more MLC NAND Flash (Samsung, Hynix, etc). We use a S34ML04 (512 MB SLC) and H27UAG8T2A (Hynix, 2 GB MLC NAND Flash)
Best regards.
Hi Bhavya,
Samsung K9G4G08U0A
Hope this helps
Alfredo
