Dear All,
We would like to use i.MX6Q in one of our design. However we are not sure if single i.MX6Q can decode four 720p channels (MJPEG) at 30 fps?
Can anyone clarify if it is possible?
If not then what is the maximum fps that can be achieved with four 720P MJPEG channels?
Dipen Patel
Solved! Go to Solution.
Hi Dipen
yes it can, some characteristics can be found in presentation
Q&A: MX6 VPU H.264 Dual Stream Encode Limits
Hi Dipen
Thanks Igor.
