Can not find connector
1,093 次查看
fabian_blatz
I am trying to get started with prototyping on an SABRE i.MX 6Quad board. The system I try to get running will use SPI and RS232 for communication to peripheral devices. Unfortunately I did not find any dedicated pins for that.
Another question that I had is how to get a debian jessie image up and running on the board? Can you just use etcher with windows similar to getting a raspberry pi up and running?
Sorry for those maybe obvious questions but I am quite new to embedded development.
标记 (2)
2 回复数
1,031 次查看
Hi Poseidon
one can try to use available connectors and select pad with necessary pinmux
options, use Chapter 36 IOMUX Controller (IOMUXC) i.MX6DQ Reference Manual
https://www.nxp.com/docs/en/reference-manual/IMX6DQRM.pdf
Guidelines for building debian jessie images can be found on BD resources
Debian Jessie images for i.MX6 boards - Boundary Devices
1,031 次查看
ZhangJennie
I suggest you move  your question to i.MX Processors
We have i.MX engineers supporting it.
Jennie Zhang
