Hi steven
i.MX23 EVK uses WQVGA LMS430 LCD Panel 4.3” Samsung display supporting
parallel 24bit RGB Interface with DE(Data Enable) & SYNC mode, Vsync, Hsync, DOTCLK signals.
While LQFP option supports 8 bits of LCD interface with modes:
8-bit serial RGB mode
ITU-R/BT.656 8-bit+clock mode
8-bit system mode
So seems it can not be used with i.MX23 EVK LCD.
you are great ! thanks.
