Can i build android image for i.mx6dl using yocto?
1,289 次查看
21300466
Hi,  i wonder that whether i can build android image for i.mx6 duallite using YOCTO.
I found many reference about building android image for imx6, but they don't mentioned about using yocto.
Is it possible?
标签 (5)
2 回复数
1,069 次查看
Rita_Wang
Here do not recommend you to use yocto to build the android images. About the android images build you can refer to our android userguide document.
1,069 次查看
Rita_Wang
Which version BSP are you using?
