Can dpu drivers demos of imx8qm run on M4 core0?
1,800件の閲覧回数
jinchen1227
I use imx8qm and want to develop demos in M4 core0.
But the dpu demos in SDK_MEK-MIMX8QM/boards/mekmimx8qm/driver_examples/dpu is only for M4 core1.
Are there any restriction for M4 core0 using dpu in imx8qm?
3 返答(返信)
1,744件の閲覧回数
Bio_TICFSL
Hello Chen,
You can use the DPU in M4 core 0, but you will change the driver.
1,744件の閲覧回数
jinchen1227
Thank you for replay, I modify the pin_mux and interrupt init, now I can use the dpu demo on M4 core0.
1,476件の閲覧回数
Yin11
Would you be able to describe a step by step instruction on how to modify pin_mux and interrupt init?
