Can SPI bus support other devices besides storage on i.MX6 Yocto?
790 次查看
charleshuang
Senior Contributor II
If yes, do you try to use any device on SPI bus?
Thank you.
Alex Cheng
标签 (4)
1 回复
733 次查看
alejandrolozan1
The SPI bus and device should be able to support slaves different than memories.
Unfortunately it seems there is no a FSL board with such configuration.
/Alejandro
