Can I.MX7 dual support 2 e-ink displays?
billy_mf_wan
I know I.MX7 dual consists of EPDC controller to connect to e-ink display. I would like to know if IMX.7 dual can support to connext 2 e-ink displays together? If yes, can show different content in each e-ink display? If no, any alternative solutions?
Bio_TICFSL
Hi Billy,
The mx7 can not support dual EPDC interface one alternate solution could be, that you should use the chip like Sii902x, mx7 can support dual display, the command depends what epdc and hdmi you use, for detailed command, you can refer to the release note.
billy_mf_wan
Thank you for your reply. However, my application is needed to connect to 2 e-ink displays together to show different page in different e-ink displays. Any other suggestion in this scenario?
