Calculating u-boot boot time for i.mx8qxp MEK
kailas_kharse
Hello Team,
I want to calculate the boot time taken by u-boot for i.mx8qxp MEK board, can you please help me out how I can calculate the boot time taken by u-boot to boot, before loading the kernel.
I tried to calculate it by using "grabserial" tool but I am not able to achieve it, can you please help me out How I can calculate the boot-time taken bu U-Boot?
Thanks & Regards,
Kailas K.
kailas_kharse
Hello Igor,
I did not find any helpful information about "calculating the boot time for u-boot" in above references, can you please point out me to any tool or procedure to calculate time taken by u-boot to boot?.
Thanks & Regards,
Kailas K.
Hi Kailas
one can add codes for toggling some gpio in various places
of scfw and uboot, then check that gpio and measure time with oscillocope .
Hi Kailas
for boot times one can look at sect.3.8 Boot Flow System Controller
Firmware Porting Guide (sc_fw_port.pdf) included in  SCFW Porting Kit​
