CTS android.holo test case not running
1,377 次查看
jblack547
When we run our 4.4_r1 test this test case does not run. Also, there is another holo test, android.host.holo and it doesn't even show up in the results.
The Freescale CTS test results do not mention this test case.
Anyone else having this experience?
Test Package     Passed    Failed   Timed Out    Not Executed    Total Tests
android.holo       0               0          0                   0                        0
标记 (2)
913 次查看
jblack547
This test is officially removed from CTS for the time being. It will be put back at a future date. I removed it from the CTS.xml file to prevent the entry from messing up our test runs. We are using proprietary hardware based on SabreSD.
913 次查看
Rita_Wang
Hi James,
Which board are you using now?
Dan
913 次查看
Rita_Wang
Hi James,
Does it work now?
Best Regards
Dan
