CST - hab4_pki_tree.sh generate keys directly to HSM ?
tomasklein
I would like you to ask, if there is any tutorial, how to use hab4_pki_tree.sh, which generate pki tree directly to the HSM ? In Code - Signing Tool - HSM, there is a part that, you write the private keys to the HSM. For my HSM, I can not write private key to HSM, I need to generate it on HSM. Now I used pkcs11-tool to generate key (pkcs11-tool --module /usr/lib/x86_64-linux-gnu/opensc-pkcs11.so -l --pin 123456 --keypairgen --key-type rsa:4096 --id 10
). Or do I need to modify the hab4_pki_tree.sh to use pkcs11-tool ?
Thanks.
Tomas Klein
Tags (3)
Yuri
    The recent CST 3.2 contains sources, therefore customers can try to
implement own solutions, more suitable for their purposes.
Yuri.
