CONFIG_CRYPTO_DEV_FSL_CAAM_SM kernel option not found
al_diallo
I am starting to work on kernel (Yocto-based) building with iMX CAAM options activated. I found all the CAAM kernel options except: CONFIG_CRYPTO_DEV_FSL_CAAM_SM, CONFIG_CRYPTO_DEV_FSL_CAAM_SM_SLOTSIZE and CONFIG_CRYPTO_DEV_FSL_CAAM_SECVIO.
What is the best approach to have these options available for activation? Or, do I need to change my kernel with a one containing these options?
Thanks in advance!
AD
Labels (4)
Bio_TICFSL
Hello DIALLO,
The Kernel Konfig is like bellow:
CONFIG_CRYPTO_DEV_FSL_CAAM=y
CONFIG_CRYPTO_DEV_FSL_CAAM_SM=y
CONFIG_CRYPTO_DEV_FSL_CAAM_SM_TEST=y
CONFIG_CRYPTO_DEV_FSL_CAAM_SECVIO=y
