CK_FTx_DCC bit value of MMDCn_MPDCCR register
takayuki_ishii
Hello community,
From rev.1 to rev.2 of Reference manual of i.MX6DP/QP, it was changed CK_FT0_DCC=100 bit setting
from "100 51.5% low 48.5% high" to "Reserved".
But Engineering Bulletin EB828(MMDC & NoC Configuration for Optimal DDR3 Performance on the i.MX 6DualPlus/6QuadPlus) not changed yet.
And Table 3.of EB828, it say that CK_FT0_DCC=100 setting is a recommended settings.
Q.1) Does it have an update of recommended setting of each CK_FTx_DCC?
Q.2) If CK_FTx_DCC=100 setting used, what happen? no effect 50%duty cycle default value?
       or it must change some other setting?
Ishii.
Labels (3)
Hi Ishii
I asked internally and got answer below from internal team:
Please follow the Engineering bulletin documents for the bit settings as it seems that Reference Manual requires the update for i.MX6DP/QP.
Hi Ishii
I will check internally and update.
takayuki_ishii
Hello Igor,
Thank you for your supports.
I am looking forward to hearing from you.
Ishii.
Hi Ishii
takayuki_ishii
Hello Igor,
Thank you for your information.
I understand that Engineering bulletin documents is oldest information in chronological order, but correct information.
Engineering bulletin   : EB828 Rev. 0, 08/2016             : 100b Increase by 1.5%
Reference Manual     : IMX6DQPRM Rev. 1, 09/2017  : 100 51.5% low 48.5% high
Reference Manual     : IMX6DQPRM Rev. 2, 06/2018  : 100 Reserved
I afraid to make mistake because my customer will be start their production based on this update.
Ishii.
takayuki_ishii
Hello community,
In EB817(SDCLK Duty Cycle Optimizations for i.MX 6Quad/6Dual), it say that CK_FTx_DCC=100 is reserved.
Does it have some difference between i.MX6 DualPlus/QuadPlus and Dual/Quad?
Or is it a mistake in document EB827?
Ishii.
takayuki_ishii
Hello community,
Some one help me?
I hope know a correct specification and recommended register value of i.MX6QuadPlus.
Ishii.
